Agree to terms checkbox
Issues related to forms.
piotrh
Post by piotrh »
Hello Pablo,
How to add "agree to terms" checkbox to form? Only by agreeing to terms someone should be able to submit message.
Bests
P
Re: Agree to terms checkbox
You can use conditions to implement this:
http://www.wysiwygwebbuilder.com/conditions.html
piotrh
Post by piotrh »
Thank You,
I followed instructions and it works,
but succes/error dialog stopped to show up after cliking submit button...
I have no what did I screwd up...
P
Here is wwb file with what I've done:
/link removed/
I cannot open your project.
Can you please remove all extensions and other non relevant content?
piotrh
Post by piotrh »
There was no other than official extensions there,
but I removed all what is not part of form.
You can download now, I've re-upladed file.
P
In 'Editbox3' there is an error in your validation settings.
If you set a minimum then the maximum value cannot be empty.
piotrh
Post by piotrh »
Pablo,
When I added maximum value - error/succes is still not showing up. But when I removed minimum and maximum value, its working.
I still dont know how to configure this object to work and correctly validate the phone number.
I also have 2 more questuions:
How to make form empty after sucessfully sending a message? Now all fields are still ocuppied with data, after message was send.
How to make submit button gray while being disabled and turn to different color after checkbox has been checked?
P
To make this work, please make sure you enter values that make sense.
When you set a minimum you will also have to set a maximum.
Also, in 'Numeric format' you did not enter any values.
How to make form empty after successfully sending a message?
This require a custom script.
You can use pseudo classes to implement styles for different states.
http://wysiwygwebbuilder.com/pseudoclasses.html
:disabled can be used disabled objects.
:checked can be used for checked objects.
More info:
https://www.w3schools.com/css/css_pseudo_classes.asp
piotrh
Post by piotrh »
Thank You, I'll try to dig deeper into it.
Would be nice if WWB had option to do that :)
If the form stays ocuppied with data, does it mean that site uses cookies already?
P
Or the browser is configured to use 'auto complete'
