Hello,
I use an InlineFrame on a webpage with two breakpoints and want to assign the following styles to it.
Default: transform-origin: 0 0; transform: scale(1.0);
Breakpint 800px: transform-origin: 0 0; transform: scale(2.1);
The InlineFrame should be stretched by a factor of 2.1 for viewports smaller than 800 pixels.
Stretching works so far, but I don't get it to separate the stretching for each breakpoint. The IFrame is stretched in every breakpoint by factor 2.1. I tried it with the StyleManager (created a Style with two breakpoints) and the OnLoad Event of the Page but this doesent work for me.
How can I realize that a different styles are used depending on the breakpoint?
Thank you very much for help.
Markus
Using WebBuilder 14.3.4
IFrame, separate Style in each breakpoint. How?
Re: IFrame, separate Style in each breakpoint. How?
First note that I cannot assist you with custom code.
But if you want to apply different style for a breakpoints then you will have to add a media query to your code.
Something like:
Something like:
@media only screen and (max-width: 800px)
#inlineframe
Great, pablo!
Thank you very much,
I have to place the following code into the "Before Tag"-Tab of the IFrame Object and its working like a charm.
<style>
#EPGFrame
</style>
