Firefox & Chrome/safari behave differently with a navigation menu
alan_sh
Nav bar doesn't work properly in safari or chrome on iPad
Post by alan_sh »
I have a page with a navigation bar on it (here http://pennine2020.penninescouts.org.uk/Members.html).
On an iPad in landscape mode - use Safari and I have to press the menu item ("Training" for example) twice to change to the corretc page. On Firefox on the iPad, I only have to press it once. Chrome on iPad works the same as Safari.
Anyone know why this happens? I need a single finger press to change pages (like FireFox).
cheers
Alan
Re: Nav bar doesn't work properly in safari or chrome on iPad
This is normal behavior for rollover elements, this is unrelated to WWB.
The first 'click' sets the hover state and the second click activates the link.
If you do not want rollover behavior then set the same properties for both states.
alan_sh
Post by alan_sh »
Ah that's good to know.
How do I set the property?
Alan
You can set the style of the buttons in the proprieties of the navbar.
alan_sh
Post by alan_sh »
I fixed it by changing to a CSS menu which has the behaviour I wanted. I didn't see anything about setting rollover/hover properties in the nav bar style settings.
Alan
Just make sure the settings for the normal button and hover buttons are the same.
alan_sh
Post by alan_sh »
Everything going swimmingly now - this issue is, I am sure, nothing to do with WWB, but I thought I'd ask here anyway.
I have a navigation menu on some of my pages. When I try it out uising my iPad tablet, Firefox works fine when you touch a menu item (it goes to the linked page), but Chrome and Safari require two touches - one to highlight it and the next one to action it.
Is there anyway around this? If not, is there another navigation menu I can try that will work?
thanks
Alan
alan_sh
Re: Firefox & Chrome/safari behave differently with a navigation menu
Post by alan_sh »
I realised after I wrote this, that I'd already asked the same question - and the answer was to make the hover color the same.
Haveing said that, I like the look of the CSS menu so I'm using that.
Alan
