V14 x86 and V15 x64 installed. Is it safe to uninstall V14?
Markus
Post by Markus »
Hello Pablo,
havent found an answer in the faqs or via serach...
On my PC I have installed version 14 x86 and version 15 x64 parallel. Since there are no problems with version 15 x64 so far, I want to uninstall version 14 now. My question: Is it safe to uninstall version 14 or are there shared resources that are accidentally deleted due to the uninstallation process?
Markus
Re: V14 x86 and V15 x64 installed. Is it safe to uninstall V14?
Yes, you can safely uninstall WWB14. It will not remove your project files or other personal files.
