Phone number format
JohnR
Phone number format
Post by JohnR »
How can I edit a phone number so that the dashes appear when submitted in a form?
Re: Phone number format
It can done using regex see the following for Telephone Number Validation
Similar Question
Similar
JohnR
Post by JohnR »
Where do you place the expression, e.g. /^(\()?\d{3}(\))?(-|\s)?\d{3}(-|\s)\d{4}$/
In the Editbox properties you can set the validation data type to 'custom'
JohnR
Post by JohnR »
I set the Data Type to 'Custom' and placed /^(\()?\d{3}(\))?(-|\s)?\d{3}(-|\s)\d{4}$/
in the Custom Expression box but it doesn't make any difference.
There is no standard solution for this in HTML, this require a custom script.
Sorry about that may be this will help
https://stackoverflow.com/questions/278 ... ing-jquery
JohnR
Post by JohnR »
I checked the above link and ran the snippet. Now the question:
where do I place
Var Phone...
$('#phone'...
and
<script src...
Place the following between the <head></head> in Page HTML then change the ID of the input "Editbox" to phone
<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.0/jquery.min.js"></script>
<script>
$('#phone').focusout(function() {
  function phoneFormat() {
    phone = phone.replace(/[^0-9]/g, '');
    phone = phone.replace(/(\d{3})(\d{3})(\d{4})/, "($1) $2-$3");
    return phone;
  var phone = $(this).val();
  phone = phoneFormat(phone);
  $(this).val(phone);
</script>
JohnR
Post by JohnR »
I tried this with the PAGE HTML and it doesn't seem to work.
Could it be because the phone number is in a FORM?
