Google Search Console reports multiple redirect errors
oldwebman
Post by oldwebman »
I am getting error reports from the Google Search Console that multiple pages on my website have redirects where no redirection has been set. They do all use a content place holder to display a menu that is located on my master page. Previously this hasn't been reported as an error. I am not sure whether I should have uploded the master page. I do exclude it from the site map.
wwonderfull
Re: Google Search Console reports multiple redirect errors
Post by wwonderfull »
Maybe you have not set pages which are canonical. Make sure all non-canonical pages redirect to one single url.
Web Development Service:Website | Contact Form
Without seeing what you have done it will be difficult to help you.
If you need help then please try to be more specific.
Are you sure you are not using any redirects such as in the likes of a .htaccess. What is the error message you are getting when inspecting url's in Google Search Console. How are you indexing the page(s) are you using the likes of nofollow, noindex. Are you using more than one menu? Is the following the site in question?
http://www.alanhawkins.net/index.html
