Installation won't overwrite a.ttf file
alan_sh
Post by alan_sh »
Every time you produce a hotfix, I go and get it and update my PCs.
As you can see from the picture below, I always get this error. I click on 'skip' and the installation carries on.
Also as you can see, I do not have WB15 open - in fact the PC has just resumed from hibernation.
Any ideas?
Alan
Re: Installation won't overwrite a.ttf file
This means that the file is still in use.
Please make sure all other applications are closed before you run the setup.
or else simply ignore the error.
Billywiz
Post by Billywiz »
Same Here, just ignored it anyway.
The Cheapest Car Hire, Worldwide.
Summit Car Hire
alan_sh
Post by alan_sh »
The file is not in use as far as I know. The only app that uses it is WB15 and that was closed yesterday. So, when you close WB15, do you ensure that TTF font is closed?
This never happened in WB14.
Alan
Yes, of course.This functionality has not changed compared to previous versions.
But in your screenshot there are a lot of other apps open. Are you sure none of these apps picked up the font and uses it?
rasure
Post by rasure »
I had this happen for the first time a few days ago. Best to restart your computer before installing.
