*** SOLVED *** Images not showing under photo gallery filter labels in v16
dapson
Post by dapson »
I tried using the filter option to apply respective labels to images in the photo gallery tool in version 16. Strangely, when I preview the project files, I see all images listed under all. However, when I click on any of the other labels, nothing shows.
any assistance with this would be very much appreciated.
Re: Images not showing under photo gallery filter labels in v16
Please share a demo project.
Related FAQ:
dapson
Post by dapson »
Pablo wrote: Sat Sep 05, 2020 8:26 pm To be able to help you, I need to see what you have done.
Related FAQ:
Okay sure, doing that shortly.
You have set the photo gallery thumbnail size to 'compatible'. This will load an old version of the gallery which does not support filters.
Please set the thumbnail size to 'responsive'
dapson
Post by dapson »
Pablo wrote: Sat Sep 05, 2020 8:40 pm You have set the photo gallery thumbnail size to 'compatible'. This will load an old version of the gallery which does not support filters.
Oh okay. Thank you very much. That works well.
