Missing Borders
ghines
Missing Borders
Post by ghines »
Hi all,
I have an HTML object inside a Layout Grid in WWB16. The HTML iframe code contains a border 5px wide that should go around the calendar. However only 2 sides contain a border whether the HTML object is in or out of the Layout Grid. Same thing happens with the Google Calendar.
Below is the wbs showing the issue:
https://drive.google.com/file/d/11HWpTB ... sp=sharing
Re: Missing Borders
Note that I cannot help you with custom code. If you want to add code to the page it is assume that you know what you are doing.
But you can try to add this to the frame:
box-sizing: border-box;
Re: Missing Borders
I think it would be easier to add the border to the container rather than the iframe.
Open up your code and add the following to the class .responsive-iframe-container
border:5px solid #000000;
Change #000000 to whatever color you want.
ghines
Re: Missing Borders
Post by ghines »
@crispy68 - Thank you. Your code did the trick. :D
