Single Page Protect Option
bubblegumweb
Post by bubblegumweb »
Hi all,
I have a sample page that I have inserted from the "Login Tools" the "Single Page Protect" option and I'm having problems with the password box centering in the browser. Inside the settings for the single page protect I have selected "Center" but when previewed in my browser the password box is always to the left hand side. Is there anyway that the password box can be in the center of the browser each time the password protected page is displayed?
Am I missing something in any settings?
Regards
Gary
Re: Single Page Protect Option
What is the URL of the page?
What are your exact settings?
bubblegumweb
Hi Pablo,
the url for the protected page is: https://www.visionwebdesign.co.uk/admin.php
Reference to settings. The actual page properties are set to center page, and the password box is set to center too.
It looks like you are using JavaScript? Unfortunately, when using this method you have little control over how it looks.
I recommend to use PHP instead.
bubblegumweb
Thanks Pablo, I'll try that
