jor_s3slider 4.0
jor_s3slider 4.0
jor_s3slider 4.0
jor_s3slider update 4 is a rewrite of jor_s3slider
jor_s3slider is based upon the s3slider JQuery plugin from boban karišik
jor_s3slider is a simple and fun fade slideshow with caption box (left - right - top - bottom position)
DEMOS jor_s3slider: visit jorextensions.com
DOWNLOAD: jor_s3slider
Builder: jordan (6j6)
Additional code: jordan (6j6)
Code: boban karišik
EB version: 4.1.0
WB version: 8+
jQuery lib: 1.7.2/1.9.1/1.11.1
W3C valid: Html, Xhtml
License: released under the Creative Commons Attribution 2.5
HISTORY:
-#-#-#- update 1 -3: -#-#-#- 25/dec/09 - 18/feb/10
01. note: jor_s3slider update 4 is a rewrite of jor_s3slider (see .pdf in download)
-#-#-#- update 4: -#-#-#- 16/jun/13
01. enhanced: WB inner jQuery + UI fx
02. enhanced: multiple instances possible
03. enhanced: slider + caption dimension set by extension
04. new: option fade speed
05. new: option caption animation speed
06. new: option caption animation easing
07. changed: content is stored in jor_s3slider folder
08. new: callback after
09. enhanced: minified source .js
Code: boban karišik
EB version: 4.1.0
WB version: 8+
HISTORY:
- me.prosenjeet
Sorry for being a knob, but, what benefit we get by putting jQuery on or off?jordan wrote:jor_s3slider_update 2
added: jQuery library enable| disable
Check my WB Extensions
Check my WB Templates
www.Lucknowwebs.com
www.Lucknowwebs.com
Re: jor_s3slider_update 3
hi misaq,
image > position
cheers!
image > position
cheers!
Re: jor_s3slider_update 4
for full update history, demo and download see top post
Re:
Same question. Thanks.eggman08.2008 wrote:Hi
Great extension. Just 1 question.
In the demo here http://www.serie3.info/s3slider/demonstration.html
The text that shows has a title and normal text.
How do I have the title text set to a different size to the normal text. As far as i can see, there is no place to add a title.
hi pflournoy,
it's in the jor_s3slider..pdf you can use HTML style tags in the - caption | text - input (<strong><b><em> etc)
see also the jor_s3slider_easystart project in the download, it shows some examples ...
