i just started using EB4.1 today. After saving your extension as a .xwb file and then building to a .wbx file, and going back to the saved directory, all you get is a file with no file extension.
This file is the .wbx file apparently because you can name it and add to WB, but this doesn't seem right. Using the latest version published 8/21/2012
What am I doing wrong?
EB 4.1 is not publishing .xwb file, .wbx extension missing
gp2727
Re: EB 4.1 is not publishing .xwb file, .wbx extension missi
I cannot find anything wrong and no one has reported this before.
What are the exact steps to reproduce this?
gp2727
My apologies
... All is fine...
Publishing to a file folder with an improper name caused this issue. The folder I tried to publish to was jqzoom_ev-2.3 (2)
So a least now we know if this occurs again what to look for...
