Problem with alignment in CMS
CMS trouble shooting / FAQ:
viewtopic.php?f=10&t=43245
Magin
Post by Magin »
Good morning!
I have a problem with the CMS editor, it does not matter if it's with CKEditor, Trumbowyg, etc ... it happens with all of them,
is that when I write a text in Word for example or any other word processor with the title centered,
the subtitle centered and italic, justified paragraph etc .., I copy said text and paste it in the CMS editor, it sticks well
with the same format that I created it in Word, it is correctly previewed and everything, the problem is that when I save and show it
in CMS View it appears all without format and aligned to the left, without the spaces and everything made a disaster, it is not the same as when I have paste it,
I have looked at all the possible ways and I do not give with the problem, to see if someone can help me.
I hope I have expressed myself well,
I do not mind uploading an example capture.
Thank you very much in advance.
Re: Problem with alignment in CMS
It is always advisable to do all the writing within Web Builder itself so to ensure the formatting is valid. When you copy/paste text from MS Word or an another Word Processor it may or will contain invalid formatting. To remove any invalid formatting simply copy/paste into Notepad then into Web Builder or hold down the SHIFT key while using 'paste', this will also remove the formatting....
Please note that the CKEditor, Trumbowyg, etc are third party and not part of Web Builder and may not support copy/pasting from Word or other processors as they already have tools to format any text inserted.
The (third party) editors all use built-in editor functionality of the browser. If you copy/paste text form another editor then it may include invalid formatting and mess up the format.
You will need to do all formatting in the editor itself.
Note that WWB has not control over how these editors work. They are provided "AS IS".
