*** SOLVED *** Shape Dividers and Preloaders not working
dapson
Post by dapson »
Hello, i am having challenges with shape dividers and Preloader, nothing seems to display there when i try to use any of them.
Can any help out with what i may be missing?
Re: Shape Dividers and Preloaders not working
To be able to help you, I need to know what you have done.
Do the example templates work for you?
https://www.wysiwygwebbuilder.com/templates9.html
dapson
Post by dapson »
Let me try out one and see. I will give feedback shortly after trying.
dapson
Post by dapson »
Pablo wrote: Thu Jul 04, 2019 10:08 am To be able to help you, I need to know what you have done.
I tried out a template with the triangle dividers in it and it doesn't show here. It shows as a straight edge.
Maybe you have changed the system folder in Tools -> Options -> Files & Folder, but did not move the dividers folder?
dapson
Post by dapson »
Pablo wrote: Thu Jul 04, 2019 10:23 am Maybe you have changed the system folder in Tools -> Options -> Files & Folder, but did not move the dividers folder?
Let me see to that and give a response after.
dapson
Post by dapson »
That was right. They both work now. Thank you
dapson
Re: *** SOLVED *** Shape Dividers and Preloaders not working
Post by dapson »
A quick question. Shouldn't dividers be used at a time? I mean if i choose a particular divide for a layer and i select top for it, if i come back to select bottom, i seem to have a divider for both top and bottom. Should it be so?
Please see the description in the help and tutorial about the 'Orientation' property:
https://www.wysiwygwebbuilder.com/shape_dividers.html
dapson
Post by dapson »
Okay sure. Thank you.
miguelss
Post by miguelss »
Hi Pablo,
I have no "dividers" on my system folder: C:\Users\name\Documents\WYSIWYG Web Builder\system\dividers
It is completely empty.
Can I add from some repository or fixed from other?
Thanks in advance!
Did you change the system folder?
miguelss
Post by miguelss »
Hi Pablo,
No. It is the same, but do not worry...I just re-install it and it works! :D
Thanks anyway for your quick replay!
Cheers! :D
