Opt-In GDPR Cookie Script or Extension
TheHobbyist
Post by TheHobbyist »
Hi there,
i really need a GDPR Cookie opt-in script where Visitors can make Setitngs which cookies should be allowd an which not.
I only found W***P***s Plugins. Like this for example: https://www.webtoffee.com/product/gdpr-cookie-consent/
On the Bottom you see the Cookiebar which allows you to make Settings - Click on the "Cookie Settings" Button then you will see what i mean!
So, my question is - is something similar to this available for WYSIWYG Web Builder? Keep in Mind - the available Extensions here
like "New: Cookie Bar" and "Cookie Policy" have no "Cookie Settings" Function!
okay, hopefully someone can help me?
If somebody can can Script this for me - then i can pay some bucks too for this! Let me know!
Re: Opt-In GDPR Cookie Script or Extension
From my knowledge there is no extension "Free or Paid" available take a look at the following scripts that you can implement into WB using the HTML Object
See the following:
https://www.jqueryscript.net/tags.php?/GDPR/
There is no standard solution for this, because by default WWB does not use cookies.
If you have implemented an application that uses cookies yourself then the GDPR message should be part of that application.
TheHobbyist
This one is what i'm looking for: https://www.jqueryscript.net/other/GDPR ... lugin.html
But how i can bring this to work inside WYSIWYG Web Builder?
Any Idea? I'm not a Coder. I can also pay some Bucks for a working Solution! Let me please know Friend's!
You can add third party scripts via the HTML object.
https://www.wysiwygwebbuilder.com/add_html.html
