Scroll Effects
kevindef
Scroll Effects
Post by kevindef »
Love the effect created in the demo herewith on Scroll Effects. I tried mimicking the same effect but no joy :cry: I am after the EXACT same effect. I wonder if I can get hold of the demo project so that I can replicate the effect?
https://www.wysiwygwebbuilder.com/suppo ... fects.html
Re: Scroll Effects
kevindef
Re: Scroll Effects
Post by kevindef »
Thank you soo much Pablo. You're a legend!
kevindef
Re: Scroll Effects
Post by kevindef »
Ok, I checked it out. Unfortunately, the demo is using Flex Containers, and mine is with break points :(
kevindef
Re: Scroll Effects
Post by kevindef »
My apologies! I tried it as individual cards with your same setting on my project (minus the Flex Container) and it worked beautifully.
Thanks once again.
kevindef
Re: Scroll Effects
Post by kevindef »
Hi Pablo,
Sorry just a quick question; on the scroll effect, why does my transition on the three cards end slightly towards the top of the screen and not at the center? Is it something to do with the "scale X and Trnsalte X" ?
kevindef
Re: Scroll Effects
Post by kevindef »
BTW: I'm using a 1366 page width.
Re: Scroll Effects
The 'anchor' property of the scroll transition determines where the transition will start and end.
