Flip Switch EVENT
JohnR
Flip Switch EVENT
Post by JohnR »
I have a form with 3 Flip Switches with Yes/No settings.
When the 3rd switch is selected I want the value to change from NO to Yes and then display
a Submit button. On the first 2 switches the values change from No to Yes as expected. On the
third the Event triggers properly, but the value stays at NO.
Just wondering what I'm doing wrong?
Clicking on the first field in the form (Marriage Date) hides the Submit button.
ridgley.ca/mltest.php
Re: Flip Switch EVENT
The URL does not seem to be valid.
Also note that I cannot see what you have done based on the HTML code.
If you need help, then please provide a demo project.
JohnR
Post by JohnR »
I did indeed have an error in the link - that has been corrected.
How do I attach the project?
JohnR
Post by JohnR »
I uploaded the file - testing.wbs to my server.
Website ridgley.ca
What is the full URL of the file?
JohnR
Post by JohnR »
Sorry, but this link does not work for me.
JohnR
Post by JohnR »
I uploaded the file testing.wbs to the same server / folder my website, ridgley.ca, is on.
I guess I'm unsure as to what you're looking for. I can provide the IP address, but that would require
you having User ID / Password to access the folder.
When clicking on your link I'm getting a 404 error. Maybe .zip the file up and then upload the .zip folder to your root folder and supply a link to this zip folder.
I'm looking for the file 'testing.wbs'
However, it is not at the specified location:
www.ridgley.ca/testing.wbs
Maybe it's in a different folder?
JohnR
Post by JohnR »
I created a folder called 'test' and placed a zipped version of testing.wbs in it.
www.ridgley.ca/test should give you what want.
Still the same as you can see from the screenshot
Lets try and make this simple please go to mediafire setup a account upload the .wbs and provide the generated url and post it here.
JohnR
Post by JohnR »
Thanks for the project.
You did not add 'return true' as documented here:
https://forum.wysiwygwebbuilder.com/ ... 10&t=37833
JohnR
Post by JohnR »
I have added the java script and the Switch now toggles, but the second Event,
which is 'Show' doesn't activate. I changed the order of the Events, but it does
not seem to make a difference.
'Show' should be the first event. 'return true' is always the last.
I have tried this wot your project and it works.
