Стандартный поиск по сайту
dbnz
Post by dbnz »
Стандартный поиск по сайту. Как сделать чтобы при листании пагинации страничка поднималась в верх к шапке сайта.
Re: Стандартный поиск по сайту
Post by zinc »
Please post in English. Use Google translate if you have to but post in English so more people can help you.
Proudly running WYSIWYG Web Builder since 2007...
https://50yearsofads.com/
Standard site search. How to make the page go up to the top of the site when paging through pagination
What exactly did you do?
What are your settings?
dbnz
Post by dbnz »
https://catalog-soft.ru/index.html?q=1111
If you skip pagination at the bottom, then the page remains at the bottom
It is necessary that when you click on pagination, the page rises to the top
The pagination menu dynamically reloads the content, so it does not affect the state of the scrollbar.
dbnz
Post by dbnz »
Are there any ways to set up or change the code of acceptance of what? When pressed, scrolling to the top occurred simultaneously
I do not think there is an easy way to implement this, because how will the menu know where to scroll to?
dbnz
Post by dbnz »
In the pogination there is an arrow in front (") when you click on it, the page flips and at the same time it rises to the top
in the link is added (#)
Is it possible to do takde with the rest of the pogination?
dbnz
Post by dbnz »
for(d=0;d<r;d++)g="<a>"+(d+1)+"</a>",$("<li></li>").html(g).bind("click",
It seems to me here somewhere you can add (#) I found this code in the file wb.sitesearch.min.js
I'm sorry, I cannot help you with custom coding.
But you have a suggestion then you can post it in the 'Suggestions' section of this forum.
If more users find this useful then I will consider it for future development.
dbnz
Post by dbnz »
ОК
