*** SOLVED *** Font Size automatically changed in project
bjlolmaugh
Post by bjlolmaugh »
I just discovered a major issue on all my website. The font size on my already developed projects have changed automatically.
For example: I have the title of the paragraph at 12 Font, and the body of the paragraph at 11 Font. Now, when I open the project, the Title is 15 Font and the body is 13 Font.
This is affecting all my saved projects.
What happened and how do I fix this?
FYI .... I have made no changes to the site, nor have I made any changes to the WWB Software. This happened automatically.
See image.
Sincerely,
Barbara Lolmaugh
http://www.websitesbybarbara.com
Re: Font Size automatically changed in project
Things just don't automatically happen what version of the software are you using? What version of Windows are you using?
In most cases this will usually be related to the DPI configuration.
See the following
https://www.wysiwygwebbuilder.com/forum ... 10&t=85917
Possible other related topic
https://www.wysiwygwebbuilder.com/forum ... 10&t=34318
bjlolmaugh
Thank you.
That resolved the issue!
Sincerely,
Barbara Lolmaugh
