Scroll Effect Missing
GrahamW
Post by GrahamW »
If you ad an image to your page and select Motion Effects then tick any of the boxes under the scroll effect and close it then re open the motion effects your setting is unticked.
Graham
Re: Scroll Effect Missing
Did you set valid values?
If you leave all values at zero then nothing will set.
Related tutorial:
https://www.wysiwygwebbuilder.com/motion_effects.html
GrahamW
Post by GrahamW »
Thanks Pablo I did overlook that
