[WWB17] Global Replace Property " Font Name " issue
christiaan
Post by christiaan »
Hi Paplo,
by trying to global replace a font name in a project the selection property for the old value does only show two font names (in my case: Arial, Courier New) and not a list of all installed fonts.
Re: [WWB17] Global Replace Property " Font Name " issue
The list only includes the fonts that are used in the project.
If you think something is missing then please share a DEMO project.
christiaan
In the sample project there are 5 banners. Each of them is using a different font: Arial Black, DejaVu Sans, Courier and Georgia.
Global Replace Tool does not show any of them.
Sample Project:
http://www.filedropper.com/wwb17globalreplaceissue
The reason for this is because the output format of the Banner is set to PNG, in that case the text will be part of the image.
So, the global replace tool does not 'see' the font.
christiaan
Global replacing the banners font only is possible when the banners output format is set to " Publish as CSS " - ok.
Our project has more than 2000+ banner objects.
Not kidding, size of project file ~60MB ...and constantly increasing.
Generated web site ~880MB without images.
Any workaround possible to replace the font of all banner objects at once ? :cry:
Sorry, there is currently no workaround.
I will investigate if I can find a workaround for a future update.
christiaan
Thank you Pablo.
And as always: very prompt response 8)
jerryco
Post by jerryco »
There is a release available with this as a change:
- Improved: Added support for Global Replace in Banners and PNG output.
https://wysiwygwebbuilder.com/download.html
Above, Beyond, and @wwonderfull! <- Genuinely helps you with a powered up site that counts! Six Times Excellence! | I have a blog at King of the Sun
