Extensions Problems
underdeumbrella
Extensions Problems
Post by underdeumbrella »
Some of my extensions will not allow me to drop them on the canvas. Extensions like, Timeline, Time Circles, Triangular Menu, TreeView and a lot more..... Is any eles having the same problem as me? How would I go about fixing this.
Re: Extensions Problems
Usually this means that there are too many extensions installed.
See also this related topic:
viewtopic.php?f=5&t=93610
Based on what you describe, it means you have too many extensions installed. You will need to either uninstall some or disable them in the extension manager.
Bluesman
Post by Bluesman »
Correct me if I'm wrong Pablo and Crispy... is there not a possibility if he runs the 32-bit version, to install the 64-bit version and it handles more extensions?
But then of cause, many of the extensions must be upgraded for 64-bit version.
"Make My Day"
See my Website
It's possible that the 64-bit version supports more extensions, but it is also computer related.
underdeumbrella
Thanks. I will try that
