Responsive Menu Behavior
plat77
Post by plat77 »
Hi - In using the "resepnsive menu" navigation, it seems to overlap below content when clicked on a menu item / previewing. I'm expecting the below content to be pushed down. Is there a way to control this or a setting that needs to be applied? Thanks!
Re: Responsive Menu Behavior
Drop down menus will never push the content down. So, there is no option to control this.
plat77
Post by plat77 »
I see in your paid "bootstrap navigation" menu demos, the content is "pushed down" when the menu collapses to mobile and a menu item is selected. I may be using the wrong phrase for this desired effect, but I guess my question, is this bootstrap functionality possible with the "responsive menu"?
The responsive menu is only uses CSS (no javascript), so it does not support this functionality.
plat77
Post by plat77 »
Thanks for the explanation - understood!
