css Menu Visability
TonyC
css Menu Visability
Post by TonyC »
I have a Masterpage with a layer used as a header, on the layer are an Expandable Panel Menu, a CSS menu and some text.
The CSS Menu is set to "keep navigation visible at all times" but the menu is behind pictures and some layers and is visible on others.
I cannot sea any difference between the ones that are not visible and the ones which are.
some advice would be much appreciated.
Link to a couple of pages here " theroyalnorfolkhotel.co.uk/Test "
Thank you
Re: css Menu Visability
Usually, this is related to the z-index. You can change the order of the element on the page in the Object Manager.
Note that I cannot see what you have done based on the published page (HTML), because the software has thousands of options and millions of possible combinations.
So, there is no way to know which options you have used by looking at the HTML only.
For further details about how to share a DEMO project file, please see this FAQ:
viewtopic.php?f=10&t=82134
TonyC
Post by TonyC »
Thanks for your responce.
I realize that its controlled by the z order, but if I change the z order ir also alters the position on the page which I don't want.
What else do you need to be able to help more
Tony
If you want the menu to be on top of other content then you can place it on a "page header" and set the stack level to 'in front of content'
For further details about how to share a project file, please see this FAQ:
TonyC
Post by TonyC »
OK Thank you.
Best
