Hide an object (shape) in a Cell Grid
- Starb7
Hi Pablo
I have tried but can't seem to do it... How do I use an Event, eg OnClick, to hide (self) or an object (or show) that is with a cell grid.
I can do it when it is not in a cell grid so presumably, it's just not possible?
TIA
Paul
TIA
Paul
Re: Hide an object (shape) in a Cell Grid
This should also work when the object is inside a grid .
- Starb7
Not for me
I'll take another look to see what i am missing. Thx
If you nee further assistance then please share a DEMO project (not the full project) so I can see what you have done.
- Starb7
Will do. Thanks
- Starb7
OK, I give in! Here's a copy of the extracted page, http://supake.co.uk/testing/hidetest.zip stripped down to the bare minimum. Whagt am I missing please?
TIA
Paul
TIA
Paul
- crispy68
1. You need to hide the aboutgrid layout grid in the object manager.
2. Go to page properties --> advanced and change the jQuery version to 3.7.1. You are using a very old jquery.
I agree with Ron, the jQuery version needs to be updated.
Also, the document type in the page proprieties should be set to HTML5.
- Starb7
Thanks, odd thing is that https://supake.co.uk/ is using the same page code now and that works fine. I'll look at that jQuery version and see if that fixes it.crispy68 wrote: Thu Apr 09, 2026 9:42 pm 1. You need to hide the aboutgrid layout grid in the object manager.
Pablo, is there any checks that can be done in a project for 'outdated' parts of a site?
Paul
- Starb7
Hi Crispycrispy68 wrote: Thu Apr 09, 2026 9:42 pm 1. You need to hide the aboutgrid layout grid in the object manager.
A few tests and I can see that chaning to 3.7.1 fixes it. I didn't change to HTML 5 (to see what happens) and it works in the current HTML version but, as Pablo suggested, I will update that html version too.
Thanks for your help.
Cheers
Paul
Page -> Error reportsPablo, is there any checks that can be done in a project for 'outdated' parts of a site?
- Starb7
Thank you
Cheers
Paul
Cheers
Paul
