hi!
the template (https://www.wysiwygwebbuilder.com/suppo ... _town.html) that i used is not working on mobile phones.
i tried on chrome and safari on iphone. so some of them are not working on mobile phones? is there a something that i can do?
( the site that i used 2brosgames.com)
thanks in advance.
(i use wysiwyg 18)
template does not work on mobile phones
Re: template does not work on mobile phones
Viewing the source (html) you have inserted invalid content in your keywords section. When entering you only add a keyword separated by a comma no quotes " " no equals = just a comma ,
Incorrect
<meta name="keywords" content="" turn-based="" farming="" game">
Correct
<meta name="keywords" content=" turn-base, farming, game">
Incorrect
Correct
This may be related to the breakpoint value. In the RWD properties of the snapscroll menu. A low value will disable the menu on smaller screens.
herneise
thanks!
keywords corrected , thanks.
how can i change the breakpoint value, In the RWD properties of the snapscroll menu?
where can i find them?
thanks
thanks
Open the properties of the menu and click the "RWD" tab.
Related tutorial:
https://www.wysiwygwebbuilder.com/snapscroll.html
Related tutorial:
herneise
done.
you were right.
i made it 320. issue gone.
thanks a lot.
you were right.
thanks a lot.
