WYSIWYG Web Builder 6.5.7 update
This is a maintenance release. WYSIWYG Web Builder 6.5.7 fixes all known problems.
- Fixed: Memory leak in ImageMap
- Fixed: Bulleted list color bug.
- Fixed: Bug in Login admin update (for MySQL mode).
- Fixed: Go Menu button width calculation bug
- Fixed: Menubar underline not visible in FireFox.
- Fixed: Locked Objects on layers/forms do not move if parent moves.
How to update from previous 6.x versions?
1. Download version 6.5.7 here:
2. If you already have version 6.x you can install it over your previous version. Make sure you select the same folder!
https://www.wysiwygwebbuilder.com/wb6update.zip
