New versions of the following extensions are now available:
jQuery Accordion 1.1, jQuery Dialog 1.1, jQuery Portlets 1.1 and jQuery Tabs 1.1
These extensions have been redesigned to use built-in jQuery support of WYSIWYG Web Builder 7 and ThemeRoller themes, so it no longer causes conflicts with other jQuery based objects and older themes are no longer required.
Also updated the ConveyerBelt extension, it now uses the publish target folder locations for images (WYSIWYG Web Builder 7 feature) .
You can download the new versions through the Extension Manager (Menu->Tools->Extension Manager->Available).
These new versions only work in WYSIWYG Web Builder 7.1 or newer.
jQuery Accordion, Dialog, Portlets and Tabs updated.
