[rz] Multi-language Sites with ease *** UPD 2020-Nov-24 ***
*** IMPORTANT INFO REGARDING [RZ] EXTENSIONS ***
This section contains extensions that were created by [rz] who has sadly passed away.
These extensions are no longer available or supported, but the discussions may still be helpful for some users.
[rz] Multi-Language Site v1.2
This extension allows you to make multilingual sites with ease.
You can switch to the parallel page in just one click!
Sample projects included.
HTML 4.01 Transitional
W3C compliant
DEMO
* New in version 1.2
- Improved the language redirection module to better control the optional preload method before redirection.
- Debug mode option in the redirecter modules.
- New extension: [rz] MultiLang (country-redirect); allows to redirect the initial page (usually index) to another one based on the visitor's country.
* New in version 1.1.1
- More efficient core for the language redirector and selector modules.
- Improved images handling for iOS-based devices.
- Improved code for the optional centralized handling.
- Improved HTML4/5 conformation.
- Moved the selector core to an external library file for faster browsing.
- Optional extension core: Now [rz] MultiLang (lng-core) is optional and with it you setup the common behavior for all the multilanguage instances.
- Improved code: Compatibility with [rz] Preloaded Links (both normal and lite versions).
- Improved [rz] MultiLang (lng-redirect) extension: Optionally, it can redirect when the target page is fully loaded.
- More 3D push effects.
- Push image.
- Images for "onhover" and "onpush" events are optional.
- Full functional three sample projects included.
* New extension in 1.0.2
[rz] MultiLang (lng-redirect): This extension allows to redirect the initial page (usually index) to another one based on the browser's default language (according to the user's settings).
How to use?
1. Open a [new] project.
2. Add a new page, i.e: "language_selector".
3. Draw and grop the "[rz] MultiLang (lng-core)" extension.
4. Open its properties dialog and tell the extension what method you will use:
folders:
you will have a folder for each language, so, your site structure will look something like this:
- myproject
- index
language_selector (to be used as masterpage)
- english (folder)
- page1
- page2
- spanish (folder)
- page1
- page2
prefix:
instead of using folders for each language, you can have a page prefix:
- myproject
- index
- eng-page1
- esp-page1
- eng-page2
- esp-page2
5. For each language you will support on your site, add the "[rz] MultiLang (lng-selector)" extension.
6. Open its properties dialog and tell the extension just a few things like the language, flag, etc...
7. In each page, just drag and drop the language_selector masterpage, and now you have your site fully synchronized!
As you can see, there is only one rule:
All your pages will have the same names for each supported language, that's all.
Just choose the method: folders or prefixes.
Now, lets say you are in page2, when you click on the icon (may be a flag), you will be redirected to the "same" page2 written in the language you clicked on.
* [rz] MultiLang (lng-redirect)
How to use?
1. Just drag and drop this extension to the index page (this means the initial page) and set its parameters.
2. The default language page means the page to be launched in case the user's system has a language set-up that your website doesn't support, in other words, you didn't write/add these pages in this language yet.
3. After that, you enter the two letters that represent the language you support in your website and the page to redirect to (this means if the browser's language matches with one of the languages you support in your site).
* [rz] MultiLang (country-redirect)
How to use?
2. The default country page means the page to be launched in case the website doesn't have a contry-specific page yet.
3. After that, you enter the two letters that represent the country you want to support in your website and the page to redirect to.
Notes:
- A comprehensive two-letter-language-code list is available here: http://www.w3schools.com/tags/ref_language_codes.asp
- A comprehensive two-letter-country-code list is available here: https://www.w3schools.com/tags/ref_country_codes.asp
- The country redirecter module is distributed in an "as-is" basis; the 3rd party service may be interrupted and may take time to find and support an alternative service.
Enjoy your multilingual site!
W3C compliant
DEMO
- Push image.
How to use?
folders:
- myproject
- index
- english (folder)
- page1
- page2
- spanish (folder)
- page1
- page2
prefix:
- myproject
- index
- eng-page1
- esp-page1
- eng-page2
- esp-page2
How to use?
How to use?
Notes:
Re: Multilingual sites with ease.
[RZ], did you consider to add a language discoverer, which directly switch to the right page(s)?
Greetz. iVent
Greetz. iVent
what do you mean?
[RZ], I mean a browser language checker (like a screen checker) and based up on the discovered language switch the visitor to the different pages. So automaticly let them jump to the right language page.
Greetz, iVent
Greetz, iVent
Greetz, iVent
Greetz, iVent
understood.
this is what i use in my sites.
later next week i will try to make an extension based on the browser's settings.
thank you for your suggestion.
Whow, one post two times published! Don't know why, but okay.
[RZ] Thanks, that would be great.
nobody reported any issues with this extension.
also i'm using it in my sites and i have no problem.
if i don't see what you did, it is very difficult for me to help you.
please post your project to see what you may did wrong.
anyhow, take in count that the index is used as a "redirecter".
the index page detect the default language settings and redirects to the proper "main" page based on these settings (*). please read very carefully the attached instructions file, re-read the first post and take a deeper look at the included sample project file (it is really simple).
EDIT:
(*) with the current extension version, you will need to do it by yourself, or do it as in the sample project file. but... an add-on will soon be added to automatically do it!!
EDIT:
i see that you forgot to include the language selector in your index page; anyhow: please read the attached instruction file and the sample project file.
both are included in your downloaded extension zip file.
Re: Multilingual sites with ease *** UPDATED Jul-29-2012 ***
*** NEW extension ***
[rz] Multilang (redirect)
This extension allows to redirect the initial page (usually index) to the browser's default language (according to the user's settings).
How to use?
(download link in the first post)
How to use?
i didn't open a developer's account yet; this is the reason i post a download link, also with a demo when it is possible, if not, a sample project at least.
well, as far as i understand from your post is you found this extension useful, so, glad to know it.
thank you for your feedback.
[RZ], Unfortunaly this redirect extension doesn't show off the hard work you put into it, since it operates in the background. But anyway, this is a very, very productive exctension we all can use very well in our globalising world ;-)
Thanx, iVent
Thanx, iVent
what is "operates in the background"?
what does this mean? do you have a z-index issue?
I meant that this extension is not visible, but quietly does his job. No, I don't have any issues yet ;-) I will use it at a new website and let you know.
Greetz, iVent
Greetz, iVent
you have three extensions.
the core
the "flags"
and the initial redirecter
please take a look at the sample file included.
if you want to replace the "manual startup" in the index page, remove all of its contents and just place the redirecter instead... that's all...
the core
the "flags"
I've just found your fantastic Multilingual site. I've tried it out only on my local drive and it works very well.
Just a couple of question please.
If I prefer not to have the language selection - i.e. flags on the index page, can I just have the flags only on the language pages themselves?
For example:
Could the index page be automatically re-directed to en_page1 this would be the homepage for the English version.
..the other language Welsh could be : cy_page1 this would be the homepage for the Welsh version.
I have also managed to add a level 2 navigation. Would I need to create additional MENU pages [named MENU_services, MENU_aboutus] for different level 2 links?
What I have done, I'm not sure if I'm correct, is to create 1 master page for the INDEX [without navigation], and another MASTER PAGE for each language with the navigation menu on it, it's worked!
I look forward to any suggestions.
thank you
Eirian
For example:
thank you
Eirian
hello and thank you for your feedback
in the index page you can have the redirect extension - this extension allows you to automatically redirect to the proper language based on the user's pc settings
if the visitor's pc lang is english then will automatically be redirected to the page1 with the proper prefix, in this case en- to the page will be en-page1
if you are in cy-page2 and you click on the english icon (usually a country flag), you will be redirected to the "partner" page, this means to the en-page2
of course, in the general category you can set a default language redirection, this means, if the visitor's pc has a language that is not covered in your website, you can have a predefined language for that case, usually english or the local language where your company is located
index ) redirect extension
en-page1 \
en-page2 ) multilang extension
en-page3 /
cy-page1 \
cy-page2 ) multilang extension
cy-page3 /
[RZ] wrote:hello and thank you for your feedback
if the visitor's pc lang is english then will automatically be redirected to the page1 with the proper prefix, in this case en- to the page will be en-page1Code: Select all
index ) redirect extension en-page1 \ en-page2 ) multilang extension en-page3 / cy-page1 \ cy-page2 ) multilang extension cy-page3 /
Hi, Many thanks for your quick reply.
I have used the re-direct extension as you suggested - thanks very much. The website is not yet live - but nearly there!
thanks once again
Eirain
thanks for your feedback
so i assume that now the idea is working fine for you
let us see your work soon
the link is working fine
@[RZ] Ok not hijacking your post but I have tested the link and it is working for me with no issues..
@HansInChina it may be an issue with your IP they may not allow downloads from mediafire. You may wish to contact them and ask them this. As you can see my reply to [RZ] I do not have any issues with the download. You may also want to try another browser or PC I would also try clearing your browser cache as well.
@bf
no problems!
your post clears up the things
as you, i didn't find issues...
no problems!
you must follow the two possible structures as stated in the instructions file.
this version does not support subdirectories.
the same issue you may run when you use masterpages (now called masterobjects) when they are embedded from different folders structures.
Re: Multi-language Sites with ease *** UPD 2014-Dec-16 ***
UPGRADE AVAILABLE:
* NEW in version 1.1:
- Optional extension core: Now [rz] MultiLang (core) is optional and with it you setup the common behavior for all the multilanguage instances.
- Improved [rz] Multilang (redirect) extension: Optionally, it can redirect when the target page is fully loaded.
- Push image.
* NEW extension in v1.0.2:
[rz] Multilang (redirect): This extension allows to redirect the initial page (usually index) to another one based on the browser's default language (according to the user's settings).
- Push image.
Re: [rz] Multi-language Sites with ease *** UPD 2014-Dec-16
the "[rz] extensions" are sent to your email upon payment
just follow the links below this post, on the signature
Re: [rz] Multi-language Sites with ease *** UPD 2017-Jan-19
Re: [rz] Multi-language Sites with ease *** UPD 2017-Jan-19 ***
i wish to know if this extension also automatically adds necessary hreflang code on the pages (or all new pages)?
This code i mean:
<link rel="alternate" hreflang="en" href="https://www.domain.com" />
<link rel="alternate" hreflang="ru" href="https://www.domain.com" />
and so on
Or its something we gotta do manually?
This code i mean:
and so on
currently you need to add these entries manually
Thanks for the reply. I posted something alternative here, which i used to do in my other web design software viewtopic.php?f=5&t=81211&p=406666#p406666 maybe you can use the idea in case you'd want to update your extension to do it.
hi
please send me buy link and one website THATS USE THIS ADDON.
thanks.
thanks.
hi
the shop site is here: www.magnawebstudio.com/shop
the extension comes with sample projects for you to see
i do not publish customers sites
thanks.[RZ] wrote: Thu Jul 19, 2018 8:37 am hi
can i buy only one [rz] Multi-Language Site : $ 6.99 addon?
before , i remember shopping limited on $ 10
for further questions you can contact privately
hi
sorry for this post
we buy Item# BGP and Item# MLS with mXXXX.XXXan@gmail.com and Receive paypal verification.
but we not Receive that addons!
i send you email from my email address but not Receive answer.
can you check problem ?
sorry for this post
yes i can check what happened, however please note that this is not at all the place to post this kind of questions
extensions are sent once the paypal confirmation has been received
of course you will receive an answer in your email
ps: seems you have not seen the automatic message about transactions placed on saturdays...
Hello RZ,
Can I see a live demo for this extension? (I could not find its demo on your site).
thanks
thanks
hi
i will try to add an online demo as soon as possible
Hi RZ
Is there still no demo available?
sorry, i was busy with other projects
i will try to upload a demo as soon as i can
w/regards
w/regards
Hi
Where can i download this extension? Also i need to know how to use it, is there any tutorials?
Kind Regards
Santie
Kind Regards
Santie
extensions are sent upon payment
follow the links below, in the signature (for info and shop)
RZ Still no demo?
Is there a demo of the auto method?
it is a matter of drag and drop an extension in the initial page
then, instead of seeing what you see in the demo, the visitor is redirected to the matching language page (according to what you have in your website and the user preferences/settings of the browser visitor)
this demo was done this way just to see more explicitly what is going to happen...
I have an older version of this extension which also works like that. Is this an update?
has been upgraded for better performance and now it also has the automatic (optional) process
just take a look at the initial post to read the changelog
i already have the automatic installed with a possibility to select a language oneself in the menu. Is it possible to have them both on the same website. I.e automatic but with a possible to have visitors select another language.
of course!
the redirector should be placed in the initial page
the language selector can be placed (as a masterobjects) in each page of your site
just note there are a lot of improvements since the initial versions
Ok then i think i will give it a try together with a couple of other interesting extension of yours. One question still is how it works with upgrades. Are they included or .?
