WYSIWYG Web Builder 15.4.4 fixes known problems and includes other improvements.
What's new?
- Fixed: Issue with text initialization.
- Fixed: Issue with panel menu background alpha in breakpoints.
- Improved: Added font-size to "Single Page Protect".
- Improved: Added line-height to 'Label' object.
How to update from previous 15.x versions?
2. If you already have version 15.x you can install it in the same location as the previous version.
32bit: https://www.wysiwygwebbuilder.com/wb15update.zip
64bit: https://www.wysiwygwebbuilder.com/wb15x64update.zip
WYSIWYG Web Builder 15.4.4 update
