I'm not having too much luck with this program. I created a page, and in WYSIWYG web builder it looks like this.
http://www.electraink.com/test/tools%20 ... TSIWYG.png
But looking at it on my site it looks like this; http://www.electraink.com/test/tools.html
What am I doing wrong?
Layout question
Re: Layout question
It looks like you did not publish all files
For example, the file 'Electraink.css' is missing on the server.
nortonz
Re: Layout question
the css file is on the server.
- crispy68
Re: Layout question
If you look at the debugger in the browser, the file "Electraink.css" is missing (404 error) as stated by Pablo. Based on your html code it is looking for this file in your root directory (same as where the html file is located).
Also, I can also see that an image is missing "no caption up015". It is not recommended to use spaces in your image/file names.
nortonz
Re: Layout question
I still don't understand, both the "electraink.css, and tools.css" file are in the same directory as the tools.html. even in wysiwyg web builder program if I Preview the site it does the same thing. I don't see what I'm missing.
I renames the bad image name just haven't uploaded the changes to the site yet.
Sorry to be such a bother, I'm need to this program. I was told it was the best. My old website builder looks just fine, but I wanted to add so eCommerce to my site and couldn't get to work in the old design program.
Regards
Michael
Regards
Michael
nortonz
Re: Layout question
OK I figured out the problem, I had copied and pasted the address from another page, so no mater what I did it didn't change the font size. I deleted the links and recreated them, the problem went away.
Thanks for the help
Regards
Michael
Thanks for the help
Regards
Michael
