*** SOLVED *** Font Issue
johnsmith0251
Post by johnsmith0251 »
I updated to the latest version of WWB today. Everything was working perfect before the update. The default breakpoint looks good when I first open the file. As I click through the breakpoints, the text shrinks and when I click back to default, the text then shrinks there too. Is this a bug?
Re: Font Issue
Maybe you have enabled the following option?
Tools -> Options -> General -> Automatically scale new object in breakpoints
If you need further assistance then please try to be more specific because there are currently no known issues.
See also:
johnsmith0251
Re: Font Issue
I did check to see if that option was enabled > it's not.
Truth is, all I have to do is open the file, and once I start clicking through the breakpoint tabs (without touching anything else) the font just automatically shrinks.
Re: Font Issue
Maybe something is wrong with the DPI configuration?
https://www.wysiwygwebbuilder.com/forum ... hp?t=85917
If you need further assistance then please share DEMO project:
johnsmith0251
Re: Font Issue
It seems to be just affecting the workspace. Even though the text seems to shink there for no reason, upon preview it looks normal.
johnsmith0251
Re: Font Issue
ahhh. i thought i already had high dpi enabled.
Re: Font Issue
Did that solve the problem?
johnsmith0251
Re: Font Issue
It was an issue with the high dpi support. I did have it on prior, and in the past, when I had a problem with it, the words were huge, not small. It's what prob threw me off. Maybe when I updated it somehow turned it off?
In any case, everything is fixed, and I highly appreciate your fast response. Thank you!!
