Hi Everybody,
I'm planning to build a PopUp registration form.
From the various examples in the blocks section of WYSIWYG, it seems that I need to use
a Dialog Box to contain several Editboxes and Buttons.
I've selected Bootstrap because the pages need to adapt to screen size and I am familiar with it.
How do I control the positioning of the objects inside the Dialog Box? At the moment,all
of the objects snap to the top of the Dialog Box.
Positioning Objects in a Dialog Box?
- jPaul
Many Thanks,
-Paul-
If I wasn't so stupid, I wouldn't have to be so persistent.
-Paul-
Re: Positioning Objects in a Dialog Box?
If the dialog is flexible, then you cannot position the form elements manually, otherwise they will not be flexible.
MAX_CDF
Try using the grid system to wrap your edit boxes and buttons in rows and columns. It makes things a lot easier to arrange. If you need to tweak spacing, custom CSS for margins can help too.
