fancybox 3 and wb14 problem
wb_user
Post by wb_user »
hello
i use fancybox 3 in wb14 but next and previous arrows not show
Re: fancybox 3 and wb14 problem
By default the arrows of fancybox3 are disabled. However, this has nothing to do with WWB14.
wb_user
Post by wb_user »
i understand.
thanks.
rogerl
Post by rogerl »
Have a look at FB3 options. you need to add something like
arrows: true
in settings
rogerl
Post by rogerl »
Hi Pablo - just preparing my thoughts before going down this path. Can I just add a folder into the Lightbox area as we did with FB2 and put the files in there or have you set it up so the system Fancybox folder has to be used?
This is from the help:
Due to license restrictions we are not allowed to distribute FancyBox v3.
However if you copy the files from https://fancyapps.com/fancybox/ to Documents\WYSIWYG Web Builder\system\lightbox\fancybox, then the application will use these files instead of the included ones (FancyBox v1).
rogerl
Post by rogerl »
Yes I've read that. So are you saying to replace the v1 files with v3 then or just combine them? I have slide shows that use all 3 versions that's why it makes more sense to me to use a separate folder for each version of FB as each version is so different to the earlier ones
No, you will need to create a new folder
Then extract the downloaded files from version 3 in that folder
The software will then use these files instead of fancybox v1
wb_user
Post by wb_user »
hello
fancybox 3 has a next and previous arrows
please see : https://fancyapps.com/fancybox/3/#images-1
// Should display navigation arrows at the screen edges
arrows: true
wb_user did you read rogerl reply to you!
rogerl wrote: Wed May 09, 2018 11:17 pm Have a look at FB3 options. you need to add something like
arrows: true
in settings
wb_user
Post by wb_user »
i copy that in this box but not work https://pasteboard.co/HkPALkI.jpg
You should only add arrows: true nothing else!
wb_user
Post by wb_user »
presto
Post by presto »
The only files you will need to run fancybox 3 are "jquery.fancybox.min.css" and "jquery.fancybox.min.js" and a file "lightbox.ini" (you can copy this from the "old" fancybox). These three files only are sufficiant to run fancybox 3.
If you want to run a slideshow then you also need to add the file "slideshow.js".
There is a file "core.js", too. With this file there you can determine yourself the behavior of fancybox 3, otherwise fancybox 3 will use the default values. In this file there is a part where for example you can switch on and off the icons shown in the upper right corner of the modal window when fancybox 3 runs. And here you can also set "arrows: true" to show the navigation arrows.
All these mentioned files above should be in the folder called "fancybox", so no sub-folders are needed. This configuration works perfectly for me.
wb_user
Post by wb_user »
presto wrote: Sat May 12, 2018 12:53 pm The only files you will need to run fancybox 3 are "jquery.fancybox.min.css" and "jquery.fancybox.min.js" and a file "lightbox.ini" (you can copy this from the "old" fancybox). These three files only are sufficiant to run fancybox 3.
sorry my english is not good i download fancybox3 from that site and paste that in system\lightbox
rogerl
Post by rogerl »
I have been trying to run FB3 integrated into Slideshow and struck the same problems. You only need the 2 .min files for css and js. core is built into those files.
How does it know data-caption = title of image? - needed to run this version
Can't get arrows:true to work either
Perhaps someone could give us a working wbs file to check out.
presto
Post by presto »
rogerl wrote: Sat May 12, 2018 9:23 pmYou only need the 2 .min files for css and js. core is built into those files.
How does it know data-caption = title of image? - needed to run this version.
You need a file called "lightbox.ini" as well. This should contain these lines only:
[attribute]
rel=$ID$
[copyrights]
company=fancyapps
url=http://fancyapps.com/fancybox/3/
[init]
script=$("a[rel^='$ID$']").fancybox({$SETTINGS$});
settings=
You can copy this to any editor and then save the file as "lightbox.ini" in the same directory as the .min files
rogerl
Post by rogerl »
Yes, have that file as well.
So what script / css have you used in Head, if any and what settings did you use for lightbox, fancybox.
wb_user
Post by wb_user »
hello
"- New feature: Added the possibility to use fancybox v3. Due to license restrictions we are not allowed to distribute fancybox v3. However if you copy the files from https://fancyapps.com/fancybox/3/ to Documents\WYSIWYG Web Builder\system\lightbox\fancybox, then application will use these files instead of the included ones (fancybox v1)."
who can send me the files with .ini and .css without problem to i put that to Documents\WYSIWYG Web Builder\system\lightbox\fancybox ?
presto
This is how to use fancybox 3 in WWB 14
Post by presto »
After having installed WWB 14 you only have to create once a directory named "lightbox" with a subdirectory "fancybox" in "C:/Documents\WYSIWYG Web Builder\system".
Please not that this is the standard path and directory where WWB (both 32-bit and 64-bit version) stores important information. Most probably you won't have changed this. Please do not mix this up with the path to the programme files of WWB.
In this new directory "C:/Documents\WYSIWYG Web Builder\system\lightbox\fancybox" you only have to copy the two files from fancybox 3:
Even if you update WWB 14 it does not overwrite this directory and as long as this directory exists, WWB 14 will use fancybox 3 instead of the built-in fancybox 1.
wb_user
Re: This is how to use fancybox 3 in WWB 14
Post by wb_user »
presto wrote: Sun May 13, 2018 10:25 am After having installed WWB 14 you only have to create once a directory named "lightbox" with a subdirectory "fancybox" in "C:/Documents\WYSIWYG Web Builder\system".
i do all of this but arrows not shown :cry:
What is the URL of the page so I can see what you have done?
wb_user
Post by wb_user »
Pablo wrote: Sun May 13, 2018 11:07 am What is the URL of the page so I can see what you have done?
rogerl
Post by rogerl »
OK, in my case, using the slide show, it works and arrows and controls show by default but disappear if no screen activity. I know Janis put out a fix for that cause it annoyed users. I'll go look for that.
  • How do I get the image title to show as the caption?
  • Given that I use all 3 versions of fancybox across the site, why can't the lightbox setup in Program Files be used with a Folder "fancybox3"
please see this :
http://bit.do/egdA3
ID:
wb_تور-مجازیPhotoGallery1
I so not see any references to 'arrows: true' in the code.
Where exactly did you add it?
Because as a standard Windows user you cannot copy files to this folder.
I am not allowed to distribute fancybox3 in the setup, that is why you will need to copy the files yourself.
rogerl
Post by rogerl »
Found the answer to this - put the following into settings:
idleTime: false
Also with current version of FB3 the arrows and basic controls should show by default.
rogerl
Post by rogerl »
As an "Administrator" I have full access to all files on my system.
I setup fancybox2 in this manner and it works perfectly as a choice under "Lightbox Gallery". In fact I did this after coming across a post where you suggested this method.
This does not involve you distributing the software at all.
  • Is there some way you could expand your current method suggested for FB3 so that it doesn't overwrite fancybox default and allow us to have a fancybox2 and fancybox3 folder under this scenario?
  • I noticed after entering settings for "fancybox" and exiting in the normal manner. I then went to preview to check the page. I then went back to change settings only to find my original settings had been erased.
wb_user
Post by wb_user »
Pablo wrote: Sun May 13, 2018 11:48 am
please see this :
ID:
in ID : تور-مجازیPhotoGallery1
i set this in light box gallery - fancybox - options : https://pasteboard.co/HkZ83tT.jpg
i set this in light box gallery - fancybox - settings : https://pasteboard.co/HkZ83tT.jpg
This look correct.
Maybe this will be helpful?
https://www.wysiwygwebbuilder.com/forum ... 10&t=80753
Make sure the contents of lightbox.ini is correct.
wb_user
Post by wb_user »
Pablo wrote: Sun May 13, 2018 12:30 pm
This look correct.
can you send me https://www.wysiwygwebbuilder.com/support/fancybox3/ project folder to i preview that whats happen ?
Here's the project:
https://www.wysiwygwebbuilder.com/suppo ... x3demo.zip
Also, please be aware of the license for Fancybox 3.
rogerl
Post by rogerl »
Slideshow fancybox3 settings
if you want to show image title as caption and include image count put the following into settings:
 infobar:false,
 caption : function( instance, item ) {
    var caption = this.title || '';
    return '<span class="fancy-count">(Image <span data-fancybox-index></span> of <span data-fancybox-count></span>)</span>' + ( caption.length ? ' ' + caption : '' );
presto
Post by presto »
wb_user wrote: Sun May 13, 2018 10:49 am
This works perfectly even with arrows provided that there is a file called lightbox.ini in the original fancybox directory. This file is installed automatically when you install WWB 14.
German
Post by German »
presto wrote: Sun May 13, 2018 1:34 pm
Thank You very much. Great! It works perfect :idea:
wb_user
Post by wb_user »
Pablo wrote: Sat May 12, 2018 12:15 pm It works for me:
is it possible to send me this project file ?
See my previous reply with link.
wb_user
Post by wb_user »
Pablo wrote: Mon May 14, 2018 5:41 am See my previous reply with link.
pablo , i check this topic : viewtopic.php?f=10&p=404218#p404218 and I acted carefully
i check your project too
but fancybox arrows not work for me Even in your project
I don't know what to do
Are you sure the lightbox.ini is correct?
wb_user
Post by wb_user »
Pablo wrote: Mon May 14, 2018 7:31 am Are you sure the lightbox.ini is correct?
yes! image: https://pasteboard.co/Hl6OHxr.jpg
please note i change my system folder from wb14 settings to D
If you remorse 'lightbox.ini' does it still work?
If yes, then the location is wrong.
Post by zinc »
If you create a file called lightbox.ini and copy these
[attribute]
rel=$ID$
[copyrights]
company=Janis Skarnelis
url=http://fancybox.net/
[init]
and place the file back the folder "facybox" within your "lightbox" folder, it works. I have just tried it and no issues.
Proudly running WYSIWYG Web Builder since 2007...
https://50yearsofads.com/
wb_user
Post by wb_user »
my system folder in D:\
i set fancybox files in D:\WWB\system\lightbox\fancybox
after that i test photo gallery its load fancybox 3 , and when remove fancybox folder , its load fancybox V1 and i guess no problem for fancybox 3 files and folder location.
in D:\WWB\system\lightbox\fancybox i have lightbox.ini with
[attribute]
rel=$ID$
[copyrights]
[init]
with this .ini , arrows not shown. when i remove lightbox.ini , photo gallery is correctly work i think lightbox.ini not effect on my photo gallery
i test pablo project file ( with arrows:true config) .To be or not to be lightbox.ini in my wb system folder ( are: D:\WWB\system\lightbox\fancybox ) not effect on project photo gallery.
rogerl
Post by rogerl »
I have successfully tested both Pablo's Gallery demo and the original ice image example.
I discovered my .ini file has an extra line to that offered in this thread:
settings=
When I tested further, the Gallery example, the settings would not work unless the .ini file was in the folder whereas the slideshow example worked with or without the .ini file.
The files are in the correct location as set out in the method. (C:\Documents\WYSIWYG Web Builder\system\lightbox\fancybox)
here are the settings I have used in the slideshow example and Gallery example to further enhance the output:
infobar:false,
 loop:true,
 idleTime: false,
slideShow : { autoStart : true },
Gallery Example:
https://www.whiteshepherdsnz.com/NewSite/index.html
Slideshow Example:
https://www.whiteshepherdsnz.com/NewSite/Ice.html
mayur007
Post by mayur007 »
rogerl wrote: Mon May 14, 2018 10:15 pm I have successfully tested both Pablo's Gallery demo and the original ice image example.
settings=
infobar:false,
 loop:true,
 idleTime: false,
Gallery Example:
Slideshow Example:
thankyou it worked
rogerl
Post by rogerl »
Pablo, would I be right in saying if you have used Fancybox1 elsewhere on a site, that folder will now be over written when this one is uploaded. If so, is there some way to over come the problem.
Correct, it will affect all object that use fancybox
mayur007
Post by mayur007 »
@pablo I did as you said in the thread but the problem arised tat there no arrows to navigate
arrows true code didnt worked but the rogel code worked, but curious is there anything i needed to do it for that without using the extra code like you made it worked?
