Hello,
1- Using (Layer Menu), I'm trying to add an icon to a button name (before or after the text) with no luck, please help.
2- Using (Layer Menu), when trying to use only an icon for -one- button name the button got squashed, and I couldn't tune the padding for this particular button alone, any suggestions?
Thanks in advance for your help and time.
Kind Regards
Icon beside name
Re: Icon beside name
1. What is the exact problem? Is there an error?
2. Do you have a DEMO project?
For further details about how to share a project file, please see this FAQ:
Please do not share the full project.
Fuad
Please find a sample page with screen shot explaining the issue in the following link:
https://www.dropbox.com/scl/fi/mkzvonvc ... rw06z&dl=0
It seems to work correct in the browser.
Are you referring to the workspace rendering?
Fuad
Yes, I've just checked it and it works correctly in the browser, so can I assume it is safe to use it in my final project?
Thank You
Thank You
Yesso can I assume it is safe to use it in my final project?
Also, the workspace rendering has been improved in the latest update.
